1989 chevy 350 stalling on turns - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2011, 05:10 PM
Hello I have a 1989 Chevy Caprice 350 stock 9C1.
Most of the time When i make left hand turns the car will boggle down seems to loose power and then it will kick back in and run fine. But Most of the time after left hand turns it will shut off completely, And then start right back up..I was thinking fuel pump or fuel sending unit??? Any suggestions Thanks
Old 03-07-2011, 05:23 PM
poncho62's Avatar
Wiki Edits: 5
Is this car fuel injected or carb?
Ontario Rodders
Old 03-07-2011, 05:31 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Probably is one of the two fuel sending unit or fuel-pump. Proably the fuel pump though. Could even be a loose connection somewhere also.
Change the filter first probably needs one anyway see if it helps. JMO
Cole
Old 03-07-2011, 05:54 PM
thanks i changed the filter a month ago but it didn't change the issue and it is fuel injected
350 chevy stalling w/o known cause John Cory Electrical 2 01-11-2009 09:59 PM
1989 Chevy 350 TBI Chevy_force Engine 3 05-25-2008 02:01 AM
74 chevy stalling 65_Chevy Engine 13 08-19-2005 10:31 PM
Stalling during right hand turns jpd37 Engine 15 06-30-2005 08:38 AM
1989 Chevy 350 TBI Mikey Engine 1 05-02-2002 07:45 PM
