Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1989 Chevy 350 TBI Timing
Old 08-15-2004, 08:21 AM
TurboS10's Avatar
TurboS10 TurboS10 is offline
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Timing is controlled by the ECU I believe. If this is the case, you have to set the idle timing to match what the ECU thinks timing is. This is likely ~10, but you will need to know exactly what it is so that the ECU can properly control total timing. Once you find what it needs to be set at, just set the timing at idle just as you would normally would.
Chris
