1989 Chevy 350 TBI Timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2004, 10:06 PM
New Member
Post 1989 Chevy 350 TBI Timing
Hey hopefully someone can help me out with this. I am working on my friends 1989 Chevrolet caprice which has a 350 with TBI. I was wondering what the timing needs to be set at and if this thing has a timing advance anyone know were to look for the wire to unplug. Also I was curious as to what the firing order was for the engine and the cap, not sure if they are hooked up correctly and of course most of the books I have found suck. Thanks for any help you can offer...
Old 08-14-2004, 10:31 PM
Neophyte's Avatar
I'm not superstitious
Last journal entry: Release catch for trunk lid pt.5
I am also eager to see the answer to the timing question as I've got a 1991 TBI myself that still needs to be stripped down for replacement of rings, bearings gaskets and so on.
The firing order you will see on the intake manifold just in front of the throttle body.
Old 08-14-2004, 11:10 PM
docvette's Avatar
Wiki Edits: 12
Fire Order
[color=yellow]Doc Here
1 8 4 3 6 5 7 2.....Direction of rotation is Clockwise , # 1 plug (at stock location ) Is about 5 O'clock.
As far as the timing, I think it's controlled by the Computer on that car.
Photo to help you locate the F.O. Below...#1 is at 5 O'clock (wire with Black tape on it) The power & Tach plug on the cap faces left, Between wires 7 & 2.
Doc
[/color]
Name:	firing order.jpg
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-15-2004, 09:21 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Timing is controlled by the ECU I believe. If this is the case, you have to set the idle timing to match what the ECU thinks timing is. This is likely ~10, but you will need to know exactly what it is so that the ECU can properly control total timing. Once you find what it needs to be set at, just set the timing at idle just as you would normally would.
Chris
Old 08-15-2004, 10:07 AM
firing order is just as doc vette stated. As far as timing you need to unplug the interupter wire. not sure where it is on a caprice. On my 92 silverado it is under the panel on the firewall to the left. Most tbi's are set at 0 base timing(wire unplugged). this is a factory setting. I currently am running at 8 degrees advanced with no issues
Old 08-15-2004, 12:00 PM
Just as syclone said the factory spec is 0. However alomst all TBI's can be timing from 4-8 degrees with better power. I'd start with 4 and go from there.
Old 08-15-2004, 12:05 PM
New Member
thanks
OK thanks for all the info i got one other question is the notvs " they look like v's cut out" is the first one 0 then sencond 2, 4 and so on?
Old 01-29-2009, 09:09 PM
Timing
first notch[the bottom of valley] the one at bottom as looking at it is 0,next valley 4,8 and 12.the pointed parts are 2,6,10.
Old 01-30-2009, 05:31 PM
Buick Hybrid Guy.
Yes.. as others have said... 0deg. with the wire
The wire would be in several spots..
back of the firewall on the harness
Inside the car where the harness comes through the firewall taped to the harness.
It will be a single pin connector tan and black or tan and white.
I agree that a few more degrees of timing would help... Keep your ear open for knock/ping.
Good luck,
Scott
Old 01-31-2009, 06:13 PM
1989 Chevy 350 Timing
Thank you docorvette I am now cruzin in my 454 BB thanks to your photo, it solved my dilemma!
