1989 chevy astro van - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2007, 10:04 AM
I was wondering if anybody could tell me where the thermostatic vacuum switch is on a this 1989 chevy astro van it is a 4.3l TBI I probed the conector and am getting code 32 egr solenoid checks out egr valve also able to push on egr valve any ideas would be helpful thanks.
Old 02-09-2007, 04:02 PM
fast68's Avatar
likes chevy trucks & boobies
one in the therm housing, and another in the intake near the therm housing
cant miss them, vacuum hoses connect to them...
Old 02-09-2007, 11:05 PM
driveability's Avatar
Last journal entry: 930 4 speed transmission
Its been a long time but if you have a code 32 I don't think you use a TVS for EGR. The computer pulses the vacuum via the EGR solenoid. When the coolant get hot enough maybe 100 degrees the computer controls the system. If I remember correctly the computer will test the system behind the seen by opening the EGR valve at a time you the driver would most likely not notice it, I think at freeway speed and at the same time look at the O2 sensor voltage output looking for a change to verify in a round about way the valve is working. Hope this helps, the EGR solenoid is electric but it can't remember where it is but I think its on the passenger side of the intake manifold.
John
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
V8 Astro Van C10 Hotrodders' Lounge 24 02-28-2012 03:57 PM
Chevy Van and Pickup parts compatabilities? Gearhead forever Body - Exterior 1 04-12-2005 10:08 AM
C20 Chevy Van (Circa 83/85) KevinG Transmission - Rearend 0 03-16-2003 09:31 AM
rear end ratio (85 or newer chevy van) chrisf67 Transmission - Rearend 2 02-27-2003 03:14 PM
