1989 chevy camaro 355 twin turbos, nitrous,megasquirt ems - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-09-2011, 04:46 PM
Project89's Avatar
Originally Posted by against all odds
1) i'm confused----i thought the gm tpi system was throttle body not multi point?
2) So in general, is flux core wire welding on the exhaust ok or should we look at mig with the gas or even tig?
tpi is mpfi
tbi is throttle body
cfi (crossfire injection) is basically a dual tbi system and was used on vettes and camaros/firebirds, this system isnt worth its wieght in scrap metal
flux core mig is fine for turbo headers or any headers, just check ur welds for pin hole leaks
  #17 (permalink)
Old 10-09-2011, 07:08 PM
Project89's Avatar
the first time i fired up the motor
http://videos.streetfire.net/video/t...ly_2323424.htm
  #18 (permalink)
Old 10-10-2011, 07:52 AM
sick.. nice to see.. im a big turbo guy.. ive had 740whp toyota supras and 802whp evos.. i was going to put the banks twin turbo kit on my t-bucket but bought a blower instead.. sick to see people useing turbos!
http://t0.gstatic.com/images?q=tbn:A...CXpbIDf5bu9WDX
  #19 (permalink)
Old 10-19-2011, 08:20 PM
Project89's Avatar
got the car running and driving now, had a big issue with my dual 340LPh fuel pumps overpowering my 3/8's return line, so i was ending up with fp at 72ish psi at idle, causing my injectors to act much much larger.
anyways the car was due to goto the body shop in 2 months but they called a few days ago to tell me they could fit the car in on the 1st
so i started to do the body work on the car
first up was the hood
http://i76.photobucket.com/albums/j3...018_190038.jpg
http://i76.photobucket.com/albums/j3...018_190110.jpg
the plan is one panel a day then get body filler on it and sanded then off to the body shop for the paint.
i did the hood entirely by hand, but hell with dooing the rest by hand tommorow im running out and getting a da sander, then after that ill body fill were needed and sand by hand
the hood was also the worst panel on the car, the roof is second though that might need a total strip down to bare metal, wont know until i start sanding it tommorow.
other then that i got one ding in the rear quarter panel and a ding in the passenger door to fix
and today i got the hood stright and primed needed a lil bit of body filler for a few spots but not bad at all
unfortunalty the fully finished pics were way to dark ill grab some tommorow
tommorow the plan is to get the roof completly sanded and primed
  #20 (permalink)
Old 10-19-2011, 08:37 PM
Project89's Avatar
the car is getting a metalic blue paint job with metalic silver flames with some airbrushing on the outline of the flames to bring them out a bit
heres the 2 colors going on the car
  #21 (permalink)
Old 11-20-2011, 09:40 AM
Project89's Avatar
ended up swaping the cam out and pulling out my twin 340lph pumps. the return line wasplaugged up and caused the pumps to deadhead, this eventually led to pump failure, for the time ebing i installed twin corvette zr-1 fuel pumps
car deffinatly needs a retune now but its running again
heres a quick vid right after the cam swap
http://www.streetfire.net/video/twin...ap_2338607.htm
  #22 (permalink)
Old 11-23-2011, 09:56 AM
life is a temporary assignment
SWEET !!!
  #23 (permalink)
Old 11-24-2011, 09:08 AM
Project89's Avatar
Originally Posted by NEW INTERIORS
SWEET !!!
thanks, yesterday i got all the wiring done and got my wastegate refrence lines plumbed in, i need to order a 4-3 inch silicone coupler and a 3inch 90* coupler and one more blowoff valve and the motor/turbosystem aspect of the car will be done. only thing besdies that will be to install the 2 stage nitrous system
  #24 (permalink)
Old 11-24-2011, 09:19 AM
Eddie Walker
How much do you have in the engine upgrades. I have an 89 Firebird that I just bought that was hacked up with a carb engine just like yours
  #25 (permalink)
Old 11-24-2011, 09:47 AM
Landshark928's Avatar
FrankenPorsche
Great build!
One concern. Eight 65# injectors won't support over 1000HP at 85% duty cycle. Even if you crank fuel pressure up to 75psi they will barely break 900HP at 7psi boost, and mid 800s at 15psi. And that's with a conservative BSFC of .60. Many turbos are more like .65 especially with 882 heads.
You may need 80# or even 95# injectors to get to your HP goals.
  #26 (permalink)
Old 11-24-2011, 09:49 AM
Project89's Avatar
minimal amount actually
the block was a 0010 4 bolt block and had a factory forged crank so i reused all that.i had a set of rods from an old project that were already shot peened resized good arp bolts, so im in it for the cost of new pistons, rings,bearings,cam,and gasket set
reused the 882 heads.
the tpi intake cost me 300 bucks, and i went aftermarket with the ecm since they hacked the harness so add in another 300
  #27 (permalink)
Old 11-24-2011, 08:05 PM
Project89's Avatar
Originally Posted by Landshark928
Great build!
i have 2 120# injectors just upstream of the throttle body these will be spraying methanol and should carry me into the 4 digit power numbers if not the 65's will be swapped out for something larger down the road. only reason i didnt go larger on the injectors right away was because this is a street car so i wanted to make sure the car would idle and cruise well
  #28 (permalink)
Old 01-09-2012, 08:45 PM
Project89's Avatar
right foot 1 transmission 0
i knew it wouldnt last long as it was never built to handle a forced induction motor, it was built to go behind a hot n/a355 sb but i did figure it would last a lil longer then it did
round 2 to ensue soon
  #29 (permalink)
Old 01-10-2012, 06:30 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
How much boost pressure were you running? how are you tuning your air fuel ratios with those cast pistons? I have the same setup in an s10 and I think i wanna keep it in the 11s underboost to help save the pistons
  #30 (permalink)
Old 01-10-2012, 07:28 AM
TroyBoy's Avatar
Psychomotors
Looks like it is coming along nicely.
Twin turbos on a 350 camaroguy87 Engine 17 04-23-2009 06:16 AM
Twin Turbos For 454 Bb Chevy Running Weber Induction System LARRY KRAMER Engine 0 08-24-2008 01:49 PM
how to find twin turbos for chevy small block muscle cars Engine 2 09-22-2006 12:00 AM
TurboS-10, Megasquirt-where are you? adb2f Engine 10 01-08-2004 07:45 PM
85 camaro with 383 stroker with nitrous oxide or twin turbo? camaro dan Engine 0 10-08-2002 06:18 PM
