1989 chevy camaro 355 twin turbos, nitrous,megasquirt ems - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2011, 12:56 AM
Project89's Avatar
heya everyone, im not exactly new i had an account years ago but have since forgotten my login info
figured i would share my 89 irocs twin turbo build with u guys
this what the car looked like the day i got it
the car originally had an tpi l98 motor which somone swapped for a carbed 70's motor ( ugh dam ppl)
the install was totally hacked , they even put the fuel line directly to the carb with no regulator. it was just dead headed to the efi fuel pump. how the car even ran is beyond me
then they hooked up the return line to the main vacum feed on the bottom of the carb
Old 10-09-2011, 01:00 AM
Project89's Avatar
i bought the car knowing i was going to turbocharge it so this wasnt all that much of an issue to me
the first step was to strip her down and fix all the main issues with the car
first up pull the factory ecm and harness they had left in the engine bay
and then remove anything non essential to the build and gernerally just make heads and tails of the mess
once i got it stripped down i bought a used tpi system to put the car back to fuel injection
Old 10-09-2011, 01:07 AM
Project89's Avatar
this got cleaned up and installed
brand new set of precision 65# low z injectors
Old 10-09-2011, 01:15 AM
Project89's Avatar
my 32x12x4 inch air to air intercooler core
3 inch charge pipes and couplers
at first i was going to go single turbo and this is what i had bought
reman t6 tv7512 turbo
76mm compressor wheel and 87mm turbine wheel
this turbo would have supported around 800 hp flywheel
and this is it all cleaned up
this is the location i had picked out for the single turbo originally but lack of room for the 5 inch downpipe and crossover tubing had me abort the single turbo install, besdies the fact i wanted more power then the t6 turbo was capable of
dont mind the temp brackets that are holding the intercooler in place
but as u can see that massive a/a intercooler fits up in the nose very nice.
it does require some cutting off the hood latch support bracket though
Old 10-09-2011, 01:28 AM
Project89's Avatar
some blending of the throttle body inlets and polishing
got really sick of the dirty engine bay so i stripped everything i could out and hit it with black paint
at some point prior to this the heads and tpi intake got some much needed attention with the die grinder
at this point i had sold off the t6 turbo and purchased a set of t3/t4 hybrid turbos .63 ar turbins with 57mm compressors
this pair of turbos will support just shy of 1200 flywheel hp
heres a pic of those when i was mocking up the locations for them
Old 10-09-2011, 01:35 AM
Project89's Avatar
so its time to fab up the headers.
i decided on a log style header so i ordered up a flange set from summit
and 8 weld els and went at it with my cheap flux core mig
those were toped off with 2.5 inch tube to finish the logs
and i finilized the ds header and wastegate placement
with just enough room to get a 2.5 inch downpipe past the steering and master cyl/proportioning valve
Old 10-09-2011, 01:46 AM
Project89's Avatar
then the passenger side
had to notch the lower rad support to get my 2.5 inch charge pipes form the turbos to the intercooler to fit
and the 2.5 inch merge i made to merge both turbo outlets into a single 3 inch pipe
and as most of us do i hate using stainless braided hose for all the lil pokes and splinters u get from assembling them.
so for an alternative i went with fragola pushloc fittings with parker pushloc hose
this is my first time ever using pushloc stuff and i will say i will never use standard braided stainless hose again unless i have to
tfabbing up the charge pipes form the turbos to the intercooler
gauge and switch panel for inside the car
the oil drain system
Old 10-09-2011, 01:56 AM
Project89's Avatar
i need to get the rest of the pics off the camera and resized and posted but i fired the car up for the first time today
as for some of the stuff i didnt go over
the engine is a 0010 block with a factory forged crank
its .030 over with 9.2-1 cr
ported 882 heads
edelbrock cam at this time but its comming out for a 224/224 cam next spring
the fuel system consists of dual areomotive 340LPH fuel pumps
tunning is handled via the megasquirt 2 running extra code
also not pictured is the car has a 2 stage nitrous system
it is setup to start spraying a 25 shot .250 of a second after i come off the launch control/antilag button . and then sprays an additional 75 shot down track in high gear
if theres any part of the build u would like to see that isnt pictured or have any questions on it just ask
im expecting 1000+ flywheel out of this setup or damn close to it
a very similar combo
the only differences are
i have +5 ci
my turbos are 57mm instead of 50mm
and my heads are slightly better
has made 875rwhp @ 21 psi and has run 9.37 @ 149 ( not sexactly sure on the mph but i can check)
my goal is to crack 8.99 with the car come this spring
still on the todo list is
install 10pt cage
do the suspension
get sfi balancer and flywheel
and fab the parachute mount
Old 10-09-2011, 02:25 AM
Scandinavian's Avatar
http://www.backfalt.fi/indexse
Last journal entry: Torque Converter
ported 882 heads
i have +5 ci
install 10pt cage
do the suspension
This is an interesting thread Im not a big fan of Turbos/Blowers or Nitros! but still its Nice to see a build like this! Ill gess youl get a slight problem of getting upp the boost on the startingline? ore do you strangel the exhaust flow?
Old 10-09-2011, 03:04 AM
Project89's Avatar
actually i shoudl have boost by 2800 rpms with this setup, i will be launching with full boost though. the megasquirt has a launch control feature.
ill set it up so at 2,500 rpms it starts to retard the ign timing to 10adtc*
this will bring the egt's up wich will spin the turbos up faster.
at 2,900 rpms the system will start droping spark alowing raw fuel into the headers, this combined with the really late spark will ignite in the headers and immediately spin the turbos up.
ive used this system on many of my builds and it works great.
on my v6 car i can spin up a 60mm turbo to 15 psi @ 2,500 rpms in less then 2 seconds
Old 10-09-2011, 04:49 AM
Yepp thats the rigth way to do it! Theres a few guys @ my local track that use small engines with big turbos an they are FAST.. its a Real nice power adder. hers a clipp from a pretty fast Finish built Ford propably nothing compared to wath you gys got in the USA! But here its pretty bade to the bone 4 banger! http://www.youtube.com/watch?v=nYZfJ...eature=related
Old 10-09-2011, 06:54 AM
TroyBoy's Avatar
Psychomotors
I'm liking your build alot,lol. Please keep us updated.
Old 10-09-2011, 03:47 PM
Project89's Avatar
thats a bad *** lil ride one of these days i want to build a cosworth or volvo engine up juswt to do something different
ill deff keep u guys updated as of right now im having some fuel system issues.
the dual 340lph pumps are to much for my return line so i have to much fuel presure at idle which is making hell for tunning this thing at idle
Old 10-09-2011, 04:19 PM
Project89's Avatar
heres the closet things ive done to "small engines"
my friends 3.4 camaro i built
first fire
http://www.streetfire.net/video/turb...er_2031749.htm
setting up the antilag system
http://www.streetfire.net/video/bad-...ro_2034246.htm
and her is my own 2.8L camaro running a 13 flat with a 50mm turbo @ 9 psi
http://www.streetfire.net/video/130_641187.htm
car went low 12's first time out with a 60mm turbo but i need to work on the tune on it as it was still way rich
Old 10-09-2011, 05:15 PM
Banned User
1) i'm confused----i thought the gm tpi system was throttle body not multi point?
2) So in general, is flux core wire welding on the exhaust ok or should we look at mig with the gas or even tig?
Twin turbos on a 350 camaroguy87 Engine 17 04-23-2009 07:16 AM
Twin Turbos For 454 Bb Chevy Running Weber Induction System LARRY KRAMER Engine 0 08-24-2008 02:49 PM
how to find twin turbos for chevy small block muscle cars Engine 2 09-22-2006 01:00 AM
TurboS-10, Megasquirt-where are you? adb2f Engine 10 01-08-2004 08:45 PM
85 camaro with 383 stroker with nitrous oxide or twin turbo? camaro dan Engine 0 10-08-2002 07:18 PM
