1989 chevy suspension lift? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2008, 01:59 AM
I have a 1989 Chevy One ton.... I have 33 12.50x 16.5 on it now, but I am wanting 35's on it... I am wanting about a 6in lift.. Any info on suspenson lifts would be great.
Old 05-25-2008, 02:22 AM
lift
Ski Jacker is good, and will have a kit for your setup, depending on the vehicle options, You'll have to ensure that the driveline angles are in specification so that the U-joints/ shaft dosen't fail or fall out on the trails. You will have to probably re-located the transmission mount. Horse power TV is your best bet or a kit that offers all the parts if your not familiar with the process of modification to the suspension. Check you local laws, you may need to drop your rear bumper to avoid those tickets, also body and suspension lifts combined are cool and give you the added clearance that you might be needing but combined they are illegal, at least in the area where I'm at.
I believe that the 89 k3500 had solid front and rear full floating rear axles so the lift should be really easy. Get a lowered cross member and mount for the transmission, blocks and u-bolts and your set.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
P.S. & suspension tips for a 52 Chevy? panamracer Suspension - Brakes - Steering 5 04-20-2010 08:35 PM
'55 Chevy Swap to 4 Bar Parallel Suspension Merton Beebe Suspension - Brakes - Steering 19 11-18-2007 07:46 PM
39 Chevy suspension rwsmcs Suspension - Brakes - Steering 11 07-27-2006 10:53 AM
Front Suspension for 33 chevy cheezbay Suspension - Brakes - Steering 3 07-03-2003 07:51 PM
