Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1989 chevy truck aftermarket gauge install.
Old 11-17-2012, 06:52 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 2014
A mechanical temperature gauge is a sealed system with a bulb sensor and capillary tube pre-assembled to the gauge. This assembly is a fixed length and cannot be cut.
The sensor bulb must be installed in the water jacket where the stock electrical temperature sender is now.
The oil pressure gauge requires a small tube from the oil pressure port, where the stock sender is located on the engine, to the gauge.
vicrod
The Following 2 Users Say Thank You to vicrod For This Useful Post:
Hittman (11-18-2012)
