1989 chevy truck aftermarket gauge install. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2012, 01:52 PM
Hittman's Avatar
I have a 1989 chevy truck with TBI 350. Iam wanting to install aftermarket gauges. But i dont no to go with Mechanical or Electric gauges. The trucks gauges are factory Electric gauges and they run off sensors. All the gauges that i have looked that are Mechanical go in place of the stock temp sensor and oil sensor locatings. Will it hurt to just unplug them and put the new stuff in. Thanks
Old 11-17-2012, 07:52 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
A mechanical temperature gauge is a sealed system with a bulb sensor and capillary tube pre-assembled to the gauge. This assembly is a fixed length and cannot be cut.
The sensor bulb must be installed in the water jacket where the stock electrical temperature sender is now.
The oil pressure gauge requires a small tube from the oil pressure port, where the stock sender is located on the engine, to the gauge.
vicrod
The Following 2 Users Say Thank You to vicrod For This Useful Post:
Hittman (11-18-2012)
1989 chevy truck TBI 350 HEI Install Hittman Engine 14 11-18-2012 04:33 PM
Need help with fuel gauge on chevy truck? robbie43 Electrical 6 12-17-2011 11:00 AM
replacing factory in dash oil gauge with aftermarket gauge Torque454 General Rodding Tech 3 09-06-2010 02:34 PM
51 chevy truck gas gauge not working new_rat_rodder Electrical 7 02-06-2009 01:20 AM
51 chevy truck gas gauge new_rat_rodder Electrical 3 07-15-2008 07:49 AM
