Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1989 chevy truck TBI 350 HEI Install
Old 11-18-2012, 04:33 PM
Pre-Tuner Pre-Tuner is offline of tire smokin' fun
Last journal entry: 406 Build Thread
The DRAC up to '91 is inside of the cluster and not a separate unit.
If all of the gauges have issues, then there is probably one problem, not several. Could be the ground. I hate my half-moon gauges too.
The TBI distributors are still considered HEI. If you want more spark, make sure the distributor is in good condition (good cap, rotor, and make sure the pickup coil isn't falling apart), then buy a better coil from one of the aftermarket companies. Also check your timing with the timing connector disconnected.
The Following User Says Thank You to Pre-Tuner For This Useful Post:
Hittman (11-18-2012)
