1989 d150 ram 318 tbi - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2012, 07:04 PM
I have a 89 dodge ram with a 318ci with a holley tbi stock, on it It has a small miss at idle and is blowing out black smoke bad when you get on it. help me thanks
Old 02-02-2012, 09:25 PM
DoubleVision's Avatar
First off remove the air cleaner, start the engine and observe the injectors. Make sure both are spraying a pattern. If one of the gaskets blow one and in some cases both sides will be leaking fuel in. If that checks out okay the next step is to check it very carefully for vacuum leaks. On a computerized vehicle if there's a vacuum leak the engine is pulling in unmonitored air, the oxygen sensor "see's" the lean fuel mixture so it adds fuel trying to compensate for it. If there are no vacuum leaks then check the fuel pressure and spark timing, make sure they're both within spec.
Dodge Warlock Parts? ( 1980 Dodge D150 ) Silentlion_69 General Rodding Tech 6 03-24-2010 08:17 PM
What do I do with an '85 Dodge D150? Hippie Hotrodders' Lounge 10 10-08-2009 07:46 AM
Free 82 Dodge D150---43,272 miles Bryan59EC Hotrodders' Lounge 1 03-08-2008 05:39 PM
1990 dodge ram d150 v6 3.9l accel coil question heman37 Electrical 7 04-30-2007 07:57 PM
fuel pump on dodge d150 jesse01 Engine 3 08-05-2005 10:31 PM
