1989 GMC 3500 drive line - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2008, 05:34 PM
I have a 1989 GMC 3500.. I'm getting ready to put a 3in body lift and some 36's on it.. But I have some questions about my axels, and gears..It does not have the solid axel in the front, I'm not sure if the rear is limited slip? I know my tranny is a turbo 400 without overdrive and my rear gears are 4:10... I want to know what I can do to beef up my drive. any info would be great.
Jared.
Old 05-26-2008, 07:52 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Is it 6 or 8 lug ?
If you want a straight Axel you will need to find one that matches your rear or find a matched st {front back} .
you will need everything to do the conversion leaf springs mounts shock perches . . . .
you might find some good examples @
www.pirate4x4.com them guyz are crazy 4x4's ers over there lots of good rear threads
R
"SlowRide66"
"Illegitimis non carborundum"
Line lock on rear wheel Bandit1980 Suspension - Brakes - Steering 13 03-12-2010 06:53 AM
Body Line Man586 Body - Exterior 6 08-20-2004 09:24 AM
51 chevy drive line conversion. swain66 Transmission - Rearend 1 06-25-2004 02:03 PM
drive line vibrationsssssssssss onebad34 Transmission - Rearend 15 11-23-2002 11:24 AM
drive line vibration biskwik Transmission - Rearend 11 02-22-2002 08:08 PM
