1989 gta transam - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2010, 12:01 AM
1989 gta transam
can anyone give me an idea of what to do..my gta has 69000 miles on it just bought it and it starts up and runs fine but when you shut it off it will not start up, 3/4 hours later it will start up again and so on i have replaced the module on the distributer and the coil but nothing...
Old 06-23-2010, 02:29 PM
Cknarf's Avatar
Pontiac Pilot
Maybe you got a bad ground wire somewhere. My formula used to do that. After running it for a few hours, it wouldnt start, almost like it had a dead battery. If I tried to start it too long it would actually melt one of the cable ends off. Check that or your starter cable.
Old 06-27-2010, 09:20 AM
Also 3rd gen starters are prone to getting too hot from engine heat.. if you dont find a bad connection, assume its this. It's most likely the bad connection.
Old 06-28-2010, 09:20 AM
engine
thanks i`ll check the starter and connections...
Old 06-28-2010, 09:35 PM
engine
my gta will crank strong for awhile connections r good also starter is good has a new crank sensor also anymore ideas will be appreciated thanks...
1989 Trans Am Gta Ignition Coil SEEEEYAAA Electrical 1 09-13-2008 03:47 PM
1989 Trans-am GTA rear end? 454supersport Transmission - Rearend 2 08-31-2008 05:35 PM
327 '89 Trans Am GTA suggestions 3rdGenFreak Engine 2 06-29-2007 07:45 PM
pontiac to sbc swap in an 80 transam meev182 Engine 10 10-06-2005 11:00 PM
help with 1989 couger cittra3333 Engine 14 12-26-2002 12:21 AM
