1989 S-15 2.8L Manual Trans. P/U - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2012, 09:51 AM
I am stuck trying to find why my truck will start some times then other times the starter just spins and does not engage. This has been going on for a couple of years. I did replace the starter the old starter tested fine but I replaced it anyway. Yes it is properly shimmed, I can roll start with no problem but this is annoying. Any suggestions are greatly appreciated.
Old 04-19-2012, 02:16 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Have you checked for missing teeth on the flywheel?
vicrod
Old 04-19-2012, 02:31 PM
Missing Teeth
I have checked both flywheel and the starter. Minor wear on the flywheel but no missing teeth no chips. I have 117,000 original miles (23 years young) thank you for the reply
Need approx price for an 1989 trans am. BigRoy1978 Hotrodding Basics 2 12-31-2010 08:15 PM
1989 trans am ring and pinion question Jkingof956 Transmission - Rearend 1 10-08-2008 09:27 AM
1989 Trans Am Gta Ignition Coil SEEEEYAAA Electrical 1 09-13-2008 03:47 PM
1989 Trans-am GTA rear end? 454supersport Transmission - Rearend 2 08-31-2008 05:35 PM
1989 mustang trans fluid? khaotic89GT Transmission - Rearend 3 08-05-2004 08:46 PM
