1989 s10 blazer 4x4 4.3L - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2003, 08:09 PM
so my moms blazer is acting up recently, at an idle and low speeds especially turning it will just start to studder like its having a fuel delivery problem. we changed the fuel filter and it seemed to go away for awhile but recently its been really bad. so today we changed the cap/rotor/wires/plugs and its still doing it.
its a 4.3L and has 200ks
<img src="
sig/sig3.jpg">
1981 el camino
stock 305
Old 12-17-2003, 08:15 PM
poncho62's Avatar
Wiki Edits: 5
Check your fuel pressure....may be a bad fuel pump.
Also, get engine codes checked, for a bad sensor.
Old 12-17-2003, 08:16 PM
i heard maybe it could be the pcv?
<img src="
sig/sig3.jpg">
1981 el camino
stock 305
Old 12-17-2003, 08:17 PM
poncho62's Avatar
Wiki Edits: 5
Change it....only about $5
Old 12-18-2003, 02:33 PM
could it be a dirty injector? and how do you go about checking the fuel pressure
<img src="
sig/sig3.jpg">
1981 el camino
stock 305
Old 12-22-2003, 12:15 PM
ztoy's Avatar
speed freak
On my 92 I had similar problems. There is a tap on the supply line near the back of the plenum for checking fuel pressure. You have to maintain hi pressure if its fuel injected, and even a few pounds under the recommended pressure can cause problems like you are experiencing. Mine was running at about 57 and it should have been 60. I replaced the fuel pump (in the fuel tank) and it ran fine after. Be sure to buy a pump at your GM dealer as the ones at Autozone and other discount outfits only run something like 4 poles in the motor while the GM pumps run 8 poles (the more poles the better the motor) which will last lots longer.
Shortly after my supply line feeding the regulator in the plenum leaked and I had to rebuild the lines. The spider lines were ok. When this occurred it ran like ***** big time. You might want to check that out also. The kit was like $80 from CarQuest.
Just hope its NOT an injector as those babies run several hundred dollrs each!
Mike
