Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1989 SBC Valve Stem Seals
Old 10-14-2012, 09:40 AM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
GM started using positive seals on the Vortec heads. Mostly for emissions benefit. Older heads need some lube on the exhaust. The intake seals will determine oil use the most tho. Vacuum on intake side, pressure on exhaust, most of the time.
Check for excessive valve/guide clearence when you change seal. Just try to wiggle valve sideways with no spring load/pressure on it. Should be no movement on a lubed stem.
