1989 Silverado Power Steering Pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2006, 02:06 PM
Canadian Charlie's Avatar
The Big Money
Last journal entry: New Air Line Part 2
I got a couple of questions to ask about my power steering pump and hopefully someone can help
1: I just replaced the pulley for an aluminum from March Performance. I pulled the old one off and pressed on the new one. I noticed that when the engine is running it wobbles around. When I put it on it turned straight as an arrow when I spun it with my hand. Maybe the shaft on the pump isn't long enough?
2: I noticed that if I push or pull the pulley the shaft in the power steering pump moves forward or inwards about an inch. Is this normal or is my pump going to die?
Old 05-15-2006, 10:35 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Your pump is dying.
Old 05-15-2006, 02:37 PM
The Big Money
What other cars or trucks can I get a pump off?
Old 05-16-2006, 02:28 PM
Almost all GM pumps are the same. Just the bracket and the line type and size. About anything 86 and later with a V-8 and rear wheel drive will fit.
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 08:22 PM
Power Steering pump pressures Jag Daddy Engine 5 06-19-2003 01:15 PM
Lean backfire Camaro76 Engine 5 04-15-2003 06:45 PM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 10:03 PM
power steering pump impala dreaming Suspension - Brakes - Steering 3 02-15-2003 06:00 PM
