1989 suburban front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2007, 08:21 AM
Guys:
I'm not a chassis guy but here's my question. I have a 4wd suburban that I would like to change to a 2wd and then lower everything via air bags....What are my choices in achieving this. Have someone weld a new front clip, change the entire frame, or weld on uppers and lowers to the existing frame?
Thanks in advance...
Zack
Old 02-08-2007, 09:45 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Probably be the best to just find a suspension clip and have it welded on in place of the existing..be sure whoever does this knows what he is doing tho..
Sam
Old 02-08-2007, 11:04 AM
Getting rid of the 4WD? Most people go the other way. I've got a '89 GMC K1500 and I think it ouuld take a fair amount of fabrication to get rid of the torsion bars and front part of the drivetrain.
Old 02-09-2007, 09:14 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
find a 2wd. It'll be easier. MUCH easier.
Old 02-09-2007, 11:45 AM
Gearhead forever's Avatar
Someone on http://www.73-87chevytrucks.com/ has more than likely done it...I'd have to say find a 2WD also, but what the hey....
Old 02-09-2007, 05:08 PM
fast68's Avatar
likes chevy trucks & boobies
save yourself a nightmare and get a 2wd
you wil be doing alot of rive t cutting an modications
shocks mount differently to the frames, and the rad support brackts are different and so on and so forth
you will have to do everything twice, once on both frames, need a complete 2wd donor anyways, so you might as well just swap the bodies, in which would be quicker
good luck
Front clip options for 59 Suburban garretthes Suspension - Brakes - Steering 6 02-21-2009 08:02 AM
Front end mock up shows some problems, cut n weld or frame shop? Ripped Body - Exterior 9 11-26-2005 08:03 PM
front end problems tonylsg Suspension - Brakes - Steering 13 04-15-2003 07:47 PM
Mustang II front end Question horvath Suspension - Brakes - Steering 35 03-02-2003 05:08 PM
is there any front end alignment people out there? IHAVECHEVYPARTS Suspension - Brakes - Steering 5 11-26-2002 08:10 PM
