1989 th 400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2008, 06:29 PM
1989 th 400
I am putting the final touches on a swap from a 4.3 fuel injected to a 5.7 carbed engine in a 2wd Chev 1/2 ton. pickup. The tranny is the stock th 400 My question is . where is the speedometer cable? I can,t trust the ecm to put 12 volts to the tranny any more so how do I hook it up to my gas pedal? Is there a schematic out there for this application.
Thanks ,Clint
Old 11-09-2008, 12:43 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks ,Clint
I do not fully understand the questions.
The 1989 truck would not have a speed-O cable. these trucks are electronic signals from the transmission.
you want 12 volts to the tranny? Is this for the kick down of the transmission?
I do not recall how the kick down voltage was hooked up on the 1989 trucks. Perhaps some one else here can help.
Old 11-09-2008, 03:14 PM
jakeshoe's Avatar
1989 I believe the ECM triggered a relay based on TPS to activate kickdown on the TH400.
Old 11-09-2008, 03:44 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
would there be room at the gas pedal under the dash for a t-400 switch or is a carb attached kick down the idea?
Old 11-09-2008, 10:24 PM
th 400
THanks for the replies. I was having a senior moment while under the truck and not seeing the speedo cable. I am going to put a switch of some sort on the carb linkage to activate the kick down
Thanks. Clint
Installing a SB 400 in a 1989 Toyota Supra JMDigital General Rodding Tech 6 03-30-2008 05:58 PM
400 cid SBC Shades_o_Grey Engine 20 02-04-2008 01:28 PM
a budget 383 stroker build using a stock 400 GM Crank Mustangsaly Engine 7 10-15-2007 01:57 PM
383 or 400?? KFXrider88 Engine 7 06-13-2006 06:45 AM
400 For 1989 Chevy Caprice deriousb Introduce Yourself 2 03-22-2006 02:00 PM
