1990 700r Tran floor shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2013, 06:42 AM
Can someone tell me where the safety neutral switch is supposed to be located. I purchased a custom hot rod and this switch either has been removed or not working.
Thanks
fnapres
Old 03-09-2013, 08:53 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Some switches are on the shifter, some on the transmission..
do you know the brand of floor shifter the car has?
Aftermarket shifter or OEM shift adapted to the car?
Old 03-09-2013, 01:52 PM
Yes, It is a home-made shifter. ????????
If the switch is on the trans I assume it would be visible. The trans is out of a 1990 Silverado SS 454.
Sorry, but this is all additional info I have.
fnapres
89 700r won't shift into third bigals77 Transmission - Rearend 5 09-24-2011 02:14 PM
700r Wont Shift Out Of First c20lopez Transmission - Rearend 10 10-12-2010 07:56 PM
need help on converting column shift too floor shift . jody chevelle Electrical 1 11-29-2005 08:29 PM
how does 700r know when to shift? manoso Transmission - Rearend 4 05-22-2004 11:20 AM
700r shift? manoso Hotrodders' Lounge 2 05-16-2004 05:52 PM
