Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1990 Camaro, with t56 conversion, Vibration problems
Old 01-30-2012, 09:14 AM
AutoGear AutoGear is offline
Driveshaft could be dented/damaged, also check your mounts. See if you can see any wear marks from the gearbox 'chucking' back and forth..
Incidentally, are you sure your clutch is engaging and releasing properly, and that theres no problems with the fluid being contaminated? This may not explain the 'movement' but it can effect the shift quality.
