1990 Camaro, with t56 conversion, Vibration problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2012, 11:47 AM
Alright, I have 350 sbc in a 90 camaro, did a t56 from the original 700r....I tightened everything up took it out, shifts fine...only thing is it feels like the transmission is slightly rocking back and forth...it always engages into gear but some times its harder then others. Its always jerking when I'm shifting at cruising speed...I'm very cautious with it cause I don't know what's causing is...I checked the trans mount its fine...I don't know where else to look????
Old 01-29-2012, 12:41 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
3rdgenmess: I edited the thread title since you will see better response with proper info on vehicle info and problem.
The search engine also functions better if you dont use ??? !!! HELP !!! or similar stuff in a thread title.
Old 01-29-2012, 12:48 PM
shake
Did you put a pilot bearing in end of crank when you switched it over?
Old 01-29-2012, 01:01 PM
Yea I have the pilot bearing in...If its the bearing id probably be hearing noises from the front more in the area where the engine and transmission join but I only hear noises from the rear end like when I hit the gas in the lower rpms...it sounds like the driveshaft is being lodged into the pumpkin
Old 01-29-2012, 08:41 PM
Are you sure your driveshaft isn't too long with no free play?
Old 01-30-2012, 06:54 AM
The shaft is at the right length, the 3rd gen and 4th gen LT1 T56s are direct swaps everything is reusable except the torque arm mount and transmssion x-member. But then again I don't know maybe its nothing to be corncerned about I heard a 2011 challenger do the samething the other day so I guess its normal
Old 01-30-2012, 08:14 AM
Driveshaft could be dented/damaged, also check your mounts. See if you can see any wear marks from the gearbox 'chucking' back and forth..
Incidentally, are you sure your clutch is engaging and releasing properly, and that theres no problems with the fluid being contaminated? This may not explain the 'movement' but it can effect the shift quality.
Old 01-30-2012, 08:59 AM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
are your motor mount shot.. the shifter will move with the tranny as it torques over.. this is normal.. shot motor mounts can make this movement bigger.. so can a junk tranny mount.. reblead the master and slave.. it shouldn't be hard to shift..unless the hole you cut into the floor isn't big enough. and the shifter is up against the floor when the engine torques over.. start by rechecking all your bolts.. if the motor mounts are the originals, they are junk.. replace them.. same with the tranny mount..
where are you getting the info that the 3rd gen torque arm and 4th gen arm are the same and the tranny crossmemer mounting spot in the unitbody is the same.. I'd double check this before you twist your car.. 3rd gen is steel the 4th gen is alum..
1990 chevy k1500 5 speed conversion? 1990k1500 Transmission - Rearend 2 01-02-2012 05:22 PM
1990 mustang problems scarfacepittbull Engine 1 07-27-2011 05:26 AM
tcc problems in 1990 c1500 liljohnalan Transmission - Rearend 5 01-08-2011 07:44 AM
'68 Camaro front brake/disc power conversion problems nathanlburns Suspension - Brakes - Steering 9 05-14-2004 08:22 AM
1990 camaro i need help vet0059 Electrical 3 06-25-2003 01:55 AM
