1990 caprice with rear end upgrade questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2011, 06:21 PM
cudablack2004's Avatar
Hey wats up guys need a lil help... have my 90 caprice 305 tbi 200r4 trans rebuilt with 2000 rpm stall. I was told my vehicle has a 7.5 10 bolt rear with 2.43 gears. Stumbled across some parts for cheap one was a ring and pinion set with 13-42 gm 7 5/8 stamped i was told it was 3.23 gears which is perfect with 28 teath on the pinion i was just wondering if its true by any chance and will it work with my 7.5 rear and yes its a 10 bolt as well
Old 11-14-2011, 06:28 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Sounds like you have a series 2 rearend with the 2:73s and if so yes it should work fine if the 3:23 are for the series 2 rearend also.JMO
3:08:1 & down gear ratios - Series 2 case 3:23:1 & up gear ratios - Series 3
But they do have the 3:23 for the series 2, just don't know what exactly the 3:23 you have came out off. JMO
Cole
Old 11-14-2011, 08:13 PM
How can i identify that to be sure? I still have the part identification code sheet in the trunk maybe yal can school me this is my second caprice well domestic period mainly dealt with hondas so im still learning
Engine Swap: 5.7 LT1 into 1990 Caprice Classic capriceclassic1990 Engine 7 07-12-2012 03:05 PM
1990 700r4 questions Kawabuggy Transmission - Rearend 4 12-13-2010 02:50 PM
i have a 305 i got out of a 1990 caprice 74chevyflat Engine 5 03-23-2007 11:11 PM
Tranny and engine swap questions...."1990 caprice classic"th400 vs 67' muncie 4 speed 74chevyflat Engine 5 02-10-2007 10:28 PM
70 Caprice rearend size? upgrade? Gearhead70Chevy Transmission - Rearend 1 10-20-2002 11:33 AM
