1990 Chevy 350/ Just for discussion - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2010, 10:06 PM
American Muscle's Avatar
305 Turbo-Fire 240hp
Ive read lots about the 90-94 swirl port heads being not the best heads. But I can remember growing up my dad having a 1990 chevy silverado swb. And man would this truck fly. No mods at all completely stock. He could smoke the tire all the way through second. It seemed pretty fast to me, fast enough i think to drop in a hot rod and really do some stuff. Growing up I cant recall at what rpms power dropped off but I sure loved rinding with dad and the occasional peel outs. So why are these not good heads cause they seemed awesome then.
Old 12-22-2010, 10:27 PM
Wiki Edits: 31
I can do the same thing with my '95 K1500 extended cab long bed.. has a 305 and a 5spd. 1st gear is very steep, and 2nd gear is low enough to start out in. combined with the light rear end of a truck, it's a tire burner... the swirl port heads suck, because there just not good heads.. if you look at a TBI 350, they made 200hp.. the 305 makes 160 hp IIRC...
Old 12-23-2010, 12:43 AM
DoubleVision's Avatar
There`s many discussions on these heads on other web sites. Guys claim they`ve ported them and made them work as well as Vortecs. I myself don`t buy that. My 92 Chevy truck has a well warmed up 4.3 V6 TBI, 5 speed transmission and a 3.42 posi. I can roast the 9 inch wide BFGoodrich hides off the back easy. The swirl port heads make explosive low end torque but due to the swirl vane, the mixture reaches it`s maximum velocity around 3800 RPM and afterwards it falls on it`s face because it`s giving it all it can give it, the swirl vane hampers flow past that point. To combat this issue on my truck, I did some light bowl porting and installed after market Ferrea SS necked down valves plus had a back cut put on them. I have a fully ported TBI, edelbrock performer TBI intake, Venom injectors, larger roller cam, the whole 9 yards but when it reaches 4000 RPM I can feel it stop pulling. Sure, the engine will tach to 5500, but the power drops off to nothing at 4000 RPM.
Even had I fully ported the heads, I doubt it would have did much good, when a big swirl vane is made into the valve bowl it becomes a blockage at some point. This was why in the 80`s they were named "Vortec" because a "Vortex" is a tornado, the heads swirled the mixture like a tornado, so hence the name.
Old 12-23-2010, 03:10 AM
i had an '86 astro van with the 4.3l and those swirl port heads..
my dad and I (He was a GM Powertrain engineer) ground those swirl vanes out completely when we had the heads off to do valve stem seals.. they flowed so much better, the engine would hardly run on the stock tune any more.
we ended up having to build a whole new fuel and spark table for the TBI and MAN did that 4.3l scream afterwards.. made TONS more power higher up in the rpm band. I never towed with it.. so I wasn't bothered giving up a bit of low end torque for the much wider useful power band :>
Old 12-23-2010, 04:15 AM
my brother has a 94 chevy truck with stock 350, and he can blow the tires off, but I tear him up everytime with my 86 chevy truck with a mild 305. We both have 700r4 and usually are neck and neck out the gate but my little ole "305" seems to breath a little better. Where swirl ports only on trucks, did they come in any cars of that era. The reason I ask is it is more likely for trucks to have the torquey heads for hauling.
Old 12-23-2010, 09:41 AM
Last journal entry: Paint
They used swirl port heads on Caprice police cars. Sheesh, if you are only turning 2200 rpms at 75 mph how fast do you think a truck will be going at 4000 rpms?
Old 12-23-2010, 09:52 AM
Some of the TBI 350 truck engines were rated at 210 hp and some were 200 hp. I think it had to do with the exhaust.
Old 12-23-2010, 10:01 AM
Wiki Edits: 31
some had dual exhaust
Old 12-23-2010, 10:16 AM
The dual exhaust exhaust is only from the muffler back. I think they also use a different cat converter. It was sometime after 92 that the hp rating went down.
Old 12-23-2010, 11:11 AM
my '72 monte carlo does 2250 rpm @ 70
1990 chevy 350 ss swags05 Hotrodding Basics 41 12-26-2012 09:53 PM
1990 chevy 5 speed streetrodderbn Transmission - Rearend 2 03-30-2010 09:20 AM
1990 Chevy van 350? Mollard Engine 9 10-29-2004 08:55 AM
1990 chevy vette dopey Electrical 1 08-24-2004 02:28 PM
1990 chevy 350??? xxx(madmax )xxx Engine 3 03-10-2003 06:10 PM
