1990 chevy k1500 5 speed conversion? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2012, 04:36 PM
Hey, I put 285/75/16 Goodyear Duratrac tires on my 1990 chevy k1500 pickup, its a regular cab long bed. Now it lugs in and out of over drive when ever it feels like it, this is VERY annoying, to solve this problem, I'm looking to do a 5 speed conversion, my father has his own shop, so i'm not worried about labor rates, how much would it cost to convert it over, i believe i have a 700r4 in it now, AND, what would be the best tranny to put in, I have a 305 TBI engine in it right now. And will i be able to keep stock gearing for rear end, front axle, and transfer case?
Your help will be GREATLY appreciated!
Old 01-02-2012, 06:16 PM
Wiki Edits: 31
In 1990, the Getrag 5LM60 was what 5spd K1500's got. You could use 1 of them. just need, pedals, master cyl and the trans crossmember from a donor. I would use a NV-3500 from '93-'95, which which would fit the same with the same parts but is a little stronger. NV-4500 if you didn't mind it shifting like a truck
Old 01-02-2012, 06:22 PM
I found a 1990 donor truck for $800 that has a new clutch throw out bearing, pressure plate. I could probly talk him down. Other then that I'd have to buy lines and all that. I might just go with that option. I appreciate your help!! I might swap to the stronger tranny if I need to later down the road.
1990 chevy k1500 tranny stopd going into overdrive? gofastz Transmission - Rearend 2 09-06-2011 08:36 AM
1990 K1500 TBI with 1982 chevy 350 no power ljgriggs Engine 10 04-27-2011 03:02 PM
1990 chevy k1500 pickup left front axle replacement RAYFIN Suspension - Brakes - Steering 4 12-03-2010 11:01 AM
1990 chevy 5 speed streetrodderbn Transmission - Rearend 2 03-30-2010 10:20 AM
'85 700r4 work in a 1990 k1500 Burnsumrubber305 Transmission - Rearend 15 01-09-2008 12:30 PM
