1990 Chevy k1500 problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2012, 01:16 PM
Hello,
I have a 1990 Chevy k1500 that i just replace the engine in it with a high performance 350 engine. The engine will start and idle but it wont rev up when you step on the pedal and when I tried to shift it out of park to reverse nothing happen. It will shift into drive though so I'm not really sure what is going on. Can anyone help me?
Thank you
Old 07-15-2012, 01:52 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by dusjudd View Post
Hello,
Thank you
You indicate the engine will not rev up
Does the vehicle act like the trans is in gear when you have the shifter in park? Or is there an engine problem?
Is the shifter a stock GM unit? Any trans work done during engine swap?
What transmission is used?
Old 07-15-2012, 03:24 PM
Yea it will not rev. I had someone push on the pedal and the throttle body will open but it doesn't rev. It doesn't act like it is in gear when its in park. It is the factory shifter and trans. We didn't do anything to the trans when we replaced the engine. The engine seems to be working just fine.
Old 07-15-2012, 10:26 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Sounds like an engine problem if it will not rev up when in park and you say the vehicle does not act like it is in gear
Old 07-16-2012, 11:48 PM
well we got the engine to rev up and going into gear. The new problem it that it is running really hot. The timing is set at TDC. Is this the right timing for a 350?
Old 07-17-2012, 07:06 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You need to ask engine questions in the engine forum for responses
1990 chevy k1500 5 speed conversion? 1990k1500 Transmission - Rearend 2 01-02-2012 06:22 PM
1990 chevy k1500 tranny stopd going into overdrive? gofastz Transmission - Rearend 2 09-06-2011 08:36 AM
1990 K1500 TBI with 1982 chevy 350 no power ljgriggs Engine 10 04-27-2011 03:02 PM
1990 chevy k1500 pickup left front axle replacement RAYFIN Suspension - Brakes - Steering 4 12-03-2010 11:01 AM
'85 700r4 work in a 1990 k1500 Burnsumrubber305 Transmission - Rearend 15 01-09-2008 12:30 PM
