1990 Chevy SWB clutch question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2012, 06:23 PM
I have a 1990 Chevy C-1500 that originally had a 4.3 liter V6. When I purchased the truck the motor had been swapped to a GM 290hp crate engine from jegs. I am confused on what clutch I need to replace the one in it? It has the nv3500. I know that the motor is direct replacement for 80's model pickups, so the rear seals are different. Can anyone help me? Thanks. Looking at the hayes supertruck clutch.
Old 12-03-2012, 07:08 PM
chevelle_502's Avatar
Get out the ducktape...
Last journal entry: Front brakes
Wiki Edits: 5
What size ci is the engine? Since there were several v8 options that year I'd start with a part number cross check to see if any of the same fit.
Old 12-03-2012, 08:12 PM
Its 350. They had only offered clutches for the 4.3 liter V6's and the 305's that I can see. I'll keep looking. Was hoping someone had done the swap and knew right off.
Old 12-04-2012, 03:18 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There's no reason to believe the p-o used anything other than the 4.3L clutch, is there? No reason you couldn't use it too, as long as the clutch diameter will fit your flywheel. If the 305 clutch is bigger- again, as long as it fits the flywheel- use it. But I doubt there's any difference.
Be sure to resurface the flywheel, and it's a good idea to replace the pilot bearing while you're at it.
cracked dash 95 chevy swb bbc68 Interior 4 07-20-2011 11:57 AM
1959 Chevy SWB Owner texapache Introduce Yourself 2 10-05-2010 04:47 PM
manual clutch for 1990 bronco fordcrazyga Transmission - Rearend 2 10-04-2010 09:28 AM
1990 Chevy 350 question 79C10 Engine 3 01-31-2008 07:49 AM
How's this combo for a 77 swb chevy PU. Streetmaster Engine 1 07-29-2005 08:14 PM
