Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1990 Chevy truck Pitman Arm
Old 07-27-2012, 03:43 AM
dirtburner dirtburner is offline
if it was a 4 groove pitman it is possible. i think. Look at the one you took off and see if it has 4 larger grooves in the splines. Ive never seen it done so im not sure, I have however seen front ends that had an alignment attempted with bad parts, and when worn parts were installed the wheel was off.
