Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1990 Chevy truck Pitman Arm
Old 07-27-2012, 07:12 AM
pemdj pemdj is offline
It does have 4 bigger splines and it can go on 4 different ways , I took it for another drive and the steering wheel is not off that much , it is in the 10 oclock / 4 oclock position instead of the 9 - 3 oclock position , I installed a MOOG Pitman Arm , and it appears to not be exactly like the original , The Mechanic at the alignment shop said it shouldn't be a problem to staighten out the steering wheel adjusting the tie rods.
