1990 chevy wont start - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2011, 04:38 AM
i have a 1990 chevy 1500 4.3 5 speed it wont start it has power to everythnig battery and altinator are good and has a brand new starter. my problem is the starter wont ingage its like theres no power to it i also replaced the neutral saftey switch any other help would be great
Old 10-15-2011, 05:34 AM
Start troubleshooting from the starter.
- Make sure you have the large battery cable tight on the starter lug.
- (then make sure its in neutral) Use a small jumper wire from the large lug over to the small S terminal on the starter. Just hold the wire and touch it between the two points, which will apply 12 volts to the solenoid. If it turns the engine over, the starter is working.
- Now take the wire off the S terminal and put a voltmeter or test light on it. If you don't get 12 volts when you turn the key to start, you have a break somewhere. Look for breaks in the wire where it runs through a metal tube up behind the exhaust manifold and to a point behind the valve cover.
- If no breaks are obvious, then go to the neutral safety switch and pull off the plug. Use spade connectors on both ends of a jumper wire. First plug it into the ignition switch side of the plug and use a test light to make sure that you get 12 volts in start.
- If you do get 12 volts, use the jumper to bypass the neutral safety switch. If that works to turn over the starter, you just need to make some adjustments in the switch. If that does not work, you have a wire break between the neutral safety output wire and the starter solenoid. You can trace and find the break, or just run a new wire.
- If you don't get 12 volts in start at the neutral safety input, you have a bad ignition switch or a wire break between the switch and the neutral safety.
You could also reverse the process and start troubleshooting from the neutral safety switch. However, on a manual trans its probably under the the truck and not much easier to reach than the starter.
Bruce
Old 10-15-2011, 05:17 PM
EOD Guy's Avatar
Good advice above, but I'd start at the NSS 1st.
Old 10-16-2011, 09:44 AM
wont start
small wire on started should have 12 volts when key is in start position
Old 10-16-2011, 04:11 PM
thanks for the advice it was the neutral saftey switch the guy i bought it from had it wired wrong and on the wrong side of the clutch
Old 10-17-2011, 04:05 AM
EOD Guy's Avatar
Good to see you got it fixed
03 Chevy Silverado SS just wont start allaccesssys Engine 4 08-22-2011 12:02 PM
350 chevy wont start hotrod_11_12 Engine 2 03-27-2011 09:26 PM
'69 Chevy C10 Wont Start TravelingP Electrical 6 11-20-2010 03:33 PM
Chevy Beretta Still Wont Start! 1988ChevyBeretta2.8 Engine 6 03-14-2007 04:30 PM
265 chevy wont start out of time 1939 dan Hotrodding Basics 1 06-02-2004 09:26 PM
