1990 dodge dakota - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2007, 06:53 PM
68novafan's Avatar
Ford Fan At Heart
1990 dodge dakota
I have a 1990 dodge dakota. I aquired a 1992 dodge dakota 4x4 rear end with limited slip. the rear end in the 90 is a 5 lug while the 92 is a 6. is there any way to change the 6 lug to a 5 lug? can i swp out axles? any help would be great. and im pritty sure the 4x4 rear end will fit in the 90 but not possitive. thanks!
Old 10-18-2007, 07:16 PM
That year had a range of different ratios for the rear end. Make sure you got the right one by using the number on the tag attached to the housing. According to http://www.differentials.com/pdfs/38.pdf the axles from your old rear are the same length and splines, so you should be able to use them as long as the rear is the same size. Most here know more than I do about this stuff, so they will correct me if I'm wrong.
Dodge Panel Delivery with a 1993 Dakota Chassis 2craze Introduce Yourself 1 10-08-2007 06:43 AM
1990 dodge ram heman37 Electrical 4 05-01-2007 07:22 AM
97 Dodge Dakota Rick527 Transmission - Rearend 3 05-29-2005 07:11 PM
question about dodge dakota trans notmrgoodwrench Transmission - Rearend 1 05-18-2005 07:06 PM
38 Dodge Humpback Panel on Dakota Chassis> sifua Body - Exterior 2 10-23-2004 02:37 PM
