1990 dodge ram d150 v6 3.9l accel coil question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2007, 06:47 AM
Hi all
I just bought a universal super stock accel coil for my truck. but the question i have is can i replace this coil with the original and not have any problems like the points or rotor and cap going bad. I am planning on adding some new 8mm wires and a new brass cap and rotor and plugs down the line . or does this need to be done first. and what type of plugs would be the best suited. As i just dont want to reck anything in the ignition system. Thanks for any help.
Old 04-29-2007, 07:12 AM
First... you don't have points.
Second... that coil doesn't make much more power than the stock Bosch, so you won't hurt anything.
Do the tune-up!!! Stock copper-core Champions run the best in modern Dodges. Don't let the parts guy try to sell you platinum-crap plugs for it... they will foul in a week.
Old 04-29-2007, 07:16 AM
I thought i did have points cause it has the oil filled canister coil. and the coil is round not the square type. what type of ignition is this ? thanks again
Old 04-29-2007, 07:25 AM
would i be alright by putting in new accel 8mm wires, and for the plugs should i get v-groove or anything like that or just the plain single spark stock plugs?thanks again,
Old 04-30-2007, 09:47 AM
also should i gap the plugs an extra .005 or not? thanks as i am new at this and i would like to increase the spark as safely as possible and get a little better mpg , great and very informative board here. thanks again
Old 04-30-2007, 02:13 PM
accel products are garbage.Anything stock is better.Do a search on accel,you'll read other peoples' opinions.
Old 04-30-2007, 03:14 PM
thanks,
I believe ya , as that would be about my luck. oh well , guess something else to throw out. what should i get for my 1990 dodge ram v6 3.9l to make it more fuel efficient and a little extra kick. besides doing a tune up?
Old 04-30-2007, 07:57 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Better breathing, Mild cam, Performance Ignition system, Headers and low flow exhaust system, are all cheap easy upgrades..
Good maintenance is key also.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Ignition Coil resistance Question Old School Nut Engine 3 06-11-2005 03:36 PM
Big Block Tunnel Ram 2X4 Question 74NovaRat Engine 12 01-28-2005 01:22 PM
is my dodge 3.9L V6 worth keeping or should i go for a dodge 360??? mopar_101 Engine 2 07-25-2004 11:04 AM
Accel HEI Super coil question Jag Daddy Engine 3 05-31-2004 11:31 AM
Dodge V6 question Ted655 Engine 1 10-22-2002 05:23 PM
