Hi,
why do you want a 4link? are you not going to drive it on the street anymore? the tq arm setup is actually more effective than the 4 link setup, 4 links are great for drag strip and allow easy adjustments and lots of dif setups. but throw that 4link into the corners, and the tq arm will outshine it on both, the stock tq arms have been run in 3rd gen and 4th gens well into the 7s and 9s in the 1/4. the really weak point is the rear of the trans where it connects to, but that has changed also, many companies make crossmember mounted torque arms that eliminate this issue, as well as the flex. you should look around in the after market, they are developing tq arm setups for mustangs & early firebirds 67-81 chevelles & RX7's, since its an all around performer for straight line driving & cornering. the tq arm AKA three link setup.
Rich
