1990 ford 351 efi - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 10-12-2012, 07:17 PM
1990 ford 351 efi
351 efi feels like engine nosesover above 3000rpm, it feels like engine power plains out and does not want to rev .
Old 10-12-2012, 09:03 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Fuel filter, pump pressure/volume and exhaust backpressure for starting points, also make sure the timing is set right, SPOUT unplugged, and base set to 10 degrees BTDC. also, just for shiggles, hook up a dwell meter, and see if the dwell is all over the place. I know this is electronic ECM controoled ignition, but this will help eliminate a bad ECM, as it controls "dwell".
Recent Modern Electronic Engines posts with photos
1990 ford festiva captainNshaneo Engine 8 07-24-2012 09:49 AM
Need help with 1990 351 windsor! mattmar Engine 6 09-30-2010 08:47 PM
My 1990 Bronco XLT 351W EFI help... Tecchie Engine 6 02-06-2009 06:37 AM
my 1990 ford pu mooseymoose2000 Introduce Yourself 1 03-12-2006 08:20 PM
1990 Ford f-250 W/351 Nos Engine 3 03-14-2004 02:19 PM
