1990 ford festiva - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2012, 08:17 PM
1990 ford festiva
Hey guys & gals, I have a 1990 ford festiva and I cant get it started. It has spark and fuel but wont start! I changed plugs, wires, cap, rotor, coil, ignition module and nothing! ANY IDEAS??????
Old 07-23-2012, 12:44 PM
Last journal entry: after much anticipation
how much fuel...have checked to see if you have enough fuel pressure its not that common but sometimes a fuel pump will get weak instead of just failing you may be getting enough flow to get a squirt at the schrader valve but not enough to run you should be in the 35-40 psi range with key on engine off, grab a pressure gauge. hope this helps let us know the results
Old 07-23-2012, 03:44 PM
I dont have a pressure tester but i will try and get one but I tried using starting fluid and still nothing
Old 07-23-2012, 04:00 PM
sbchevfreak's Avatar
Licenced Automotive Technician
What engine?
Old 07-23-2012, 04:56 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
If it won't kick using starting fluid then you have a spark problem.
Old 07-23-2012, 05:35 PM
it has the 1.3 liter and I changed the spark plugs, wires coil and ignition module and has hot spark
Old 07-23-2012, 10:27 PM
maybe your timing is off??? stretched timing belt slipped a tooth or two? how did it run before it was shut off the last time it ran? if your cam timing is off you can have all the fuel and spark in the world but it wont run. I would still think you'd get a backfire though with the starting fluid how do you know its hot did you use a an in-line spark tester or pull a spark plug, ground it, and turn it over?
Old 07-24-2012, 10:49 AM
it doesnt back fire or nothing but i put a tester on the injector and the light is always on. is it suppose go on and off when turning over??? and i pulled the plug and it was a blue spark
and before i changed the coil it was a orangish spark
Ford Festiva not starting, need help BAD! Lee Hulick Electrical 12 03-01-2013 06:15 AM
my 88 ford festiva wont start smorris Hotrodding Basics 3 01-28-2012 05:06 PM
Wont Start,91 Ford Festiva sirlotsoflovin Engine 13 02-16-2011 06:48 PM
Ford Festiva motor swap Lee Hulick Engine 19 07-22-2005 01:55 AM
Ford Festiva Tick johnnymopar Engine 1 02-14-2003 08:38 PM
