1990 GMC 1500 rearend swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2009, 03:13 AM
Is there any rearends other then the weak gm 10 bolt that will bolt up to a 90' gmc 1500? Would a ford 8 or 9" work? or can I convert the coil-over rearend from a 1993-1997 firebird or camaro to leaf spring?
Old 01-06-2009, 06:09 AM
What about a 12 bolt?
Shane
Old 01-06-2009, 06:35 AM
SSedan64's Avatar
93-97 Fbird/Camaro rears are weak 7.5"/7.625" 10bolts. A 12-bolt or 9" would be better. You would need to swap all the brackets from your original rear.
Old 01-06-2009, 07:29 AM
TroyBoy's Avatar
Psychomotors
Curious as to why you classify them as weak 12 bolt has a smaller diameter pinion.I think 9"would be stronger,but why do you need?I know of racers running 10's with 10-bolts.I just say this to emphasize their strength.
Old 01-06-2009, 09:28 AM
SSedan64's Avatar
The 8.5" 10-Bolt is very strong stock. Except the GovLock diff. I wouldn't waste $$ on a 7.5"/7.625" 10-Bolt. Sure you can make them stronger with aftermarket Posi, Girdle & Axles. The 7.5" & 8.2" 10Bolts are weak. IMO.
8.5"Car & Truck, & 8.875"/12Bolt Car have the same 1.625" pinion dia. 30spl.
7.5" has 1.438 Pinion dia. 27spl.
8.875" 12Bolt Truck has 1.438" pinion dia.
8.2" 10Bolt has 1.438 27spl.
9" Ford has 1.313" pinion dia. 28spl./31spl.
Old 01-06-2009, 10:08 AM
prostreet6t9's Avatar
Differential/Driveline
What are you doing with the truck?
Engine swap on a 1994 Chevy 1500 4wd stfinney Engine 7 04-14-2015 06:20 AM
rearend swap johnnyblaze Transmission - Rearend 11 03-05-2008 07:12 PM
'66 Chevy rearend swap 66Chevy Man Transmission - Rearend 1 10-05-2007 09:00 AM
63 falcon (trans - rearend) swap melbishop Transmission - Rearend 2 04-16-2002 05:03 PM
BB swap into '97 GMC 1500?? Dan B. Engine 1 03-07-2002 07:43 PM
