1990 K1500 TBI with 1982 chevy 350 no power
I put a 1982 Chevy 350 into a 1990 K1500 with TBI. I used an adapter plate to mount the throttle body on the stock '82 intake. I kept every electronic component including the EST distributor except for the EGR and the knock sensor. The knock sensor did not work on the old engine and it had more power than this engine does. the engine that I put in had been rebuilt recently. The problem that I am having is when the throttle is opened quickly (such as stomping on the gas) the engine cuts out for a few seconds then picks back up but there is no power going down the road. The old engine was in bad shape and this new engine is in great shape but the old engine had more power than the new one. Things arent adding up for me so any advice would be greatly appreciated.
PS: Timing bracket is not on the timing cover and timing was set by ear and the idle is smooth as silk. |
you should take it to someone who knows how to deal with the TBI. you can't time the engine like that. there is a wire that needs disconnected IIRC. and with the knock sensor disconnected. the engine retards the timing as a failsafe.. with the engines cam possibly not being ok for the TBI. you may have more issues
Setting it by ear isn`t good enough. A TBI systems timing can be under 0 and still run. You have to know where the timing is on these engines.
The factory spark advance already greatly limits how much it gives, and if it don`t have enough timing it`s not going to have any power. Get a knock sensor for it, if it runs into detonation it`s not going to know to retard the timing which can result in engine damage. If the engine has the stock for the year it was made heads they have large inefficient chambers without swirl ports, which means it`s likely going to want more timing advance. Get some timing tabs, get a light, pull the computer wire and check it with the light. Factory calls for 0, but being it has the older non swirl port heads you can likely give it as much as 8 without issues. |
I disconnected the EST wire while trying to time the engine by ear...
Okay. But did you disconnect the batter afterwards so it would dump the previous settings? You still must know where the timing is. There`s no way around this. Until you know where it`s at your shooting in the dark.
[QUOTE=ljgriggs]I put a 1982 Chevy 350 into a 1990 K1500 with TBI. I used an adapter plate to mount the throttle body on the stock '82 intake. I kept every electronic component including the EST distributor except for the EGR and the knock sensor.
So you kept all the components for the 1990 , correct? The 82 distributor and esc wont co mingle well with a 90 TBI The adapter plate thing will cause a problem for sure,as well as not being able to time it correctly. My thoughts turned to possibly a plugged exhaust system as well. But you should put the CORRECT INTAKE on for TBI. Also you need to be sure of the timing. Dont sweat the knock sensor problem at the moment, but dont forget about it alltogether. If it is not hooked up it wont RETARD the timing as it only sends a signal when a spark knock occurs. The computer only retards the timing 3 degrees at a time when a knock signal occurs. |
[QUOTE=latech]
I am sure it doesnt have OPTIMUM airflow/performance.I think that would be a secondary issue,still worth addressing.
Focus on the timing issue, that is probably the biggest part of the problem. Knowing the other engine puked I wanted to voice my concern that the exhaust could be plugged. Just one other possisility that could be left over. I have seen plugged exhausts destroy an engine from the heat from a fuel imbalance in the system that creates a blast furnace in the cats and melts the engine and the cats down into scrap.Just my years of experience talking. Take it or leave it. |
i have the same problem cant figure it out thinking bout puting the original intake on
How do you know the knock sensor didn't work, they don't announce anything when the engine hits ping they just tell the computer to pull the timing back which it does till there's no ping it can hear. And of course you really don't know what the base timing is. Given the computer calculates timing on what it think's is throttle position, RPM, and manifold vacuum. If there's too much or too little base the amount the computer picks off the map could be in combination with the base setting too little or too much total timing either of which kills power. These are things you;ll have to check out. Bogie |
well ihave the same issue and have replaced everything im gonna put the original injection intake on this weekend will let you know if this solves the problem.
| All times are GMT -6. The time now is 07:18 PM. |
