Thanks! Thanks Top 5 Wiki Tech Article Editors! Thanks!
Updated 11/07/08
#1
Alittle1
169 edits
#2
Crashfarmer
161 edits
#3
Powerrodsmike
125 edits
#4
Techinspector1
112 edits
#5
Oldguy829
85 edits
Read and write hotrodding how-to articles on the Crankshaft Coalition Wiki. See 100+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 10-04-2006, 10:15 AM
fasteddiesage fasteddiesage is offline
1990 lincoln mark 7 leaky right front air bag suspension
Hi
Any body out there that can tell me why the right front air suspension air bag goes down while sitting over night? The air ride air bag is fairly new. Could it be a bad o-ring in the air bag solenoid itself and if so how do you go about getting the soleniod out to replace the o-rings? Thanks Alot. ED
Old 10-04-2006, 10:33 AM
KULTULZ's Avatar
KULTULZ KULTULZ is offline
aka Duke of URL
 KULTULZ's barnstar
re: 1990 lincoln mark 7 leaky right front air bag suspension
Usually when a front end goes down (while either sitting or driving) it usually indicates damaged bags and they must be replaced in pairs on the front before beginning the complete diagnostic sequence. Was the replacement bag OEM and did it come with the solenoid installed? If leaking again, it has most likely been damaged and will need to be replaced again.
The car will continue to trim itself for about five minutes (I believe) after the key is turned off. After that there is no power supplied so suspect a mechanical defect.
Use soapy water to check for a bad diaphram and/or leakage from the solenoid O-Rings/air delivery tube.
-MARK VII Air Suspension Help-
Complete diagnostics are covered in the appropriate Shop Manual and there are additional TSB's also.
Old 10-06-2006, 07:15 PM
aguila1 aguila1 is offline
Mark VIII air bag to coil spring conversion
I had the same type of problem with my Mark VIII, the portent of an air suspension system failure. Apparently salty or moist air gets in the system through the front fender mounted air compressor and starts to oxidize the airbag housings creating leaks.
My solution was to axe the entire airbag system in favor of Eibach coil springs and Koni shocks. I had to fabricate spring seats to insert in the rear spring perches where the airbags had previously sat to hold the rear coil springs. In the front I used a shock absorber housing from a Cougar to hold the Konis.
A cheaper alternative is to get the complete conversion from Strutmasters. Check out the Lincoln sites like Lincolns of Distinction for indepth info.
I have had the Mk8 converted now for a couple years and do not miss the air suspension at all. Now, it has a more performance feel and handling is much improved over the wallowy air ride. With the Eibachs the lowered stance is absolutely perfect.
Old 10-06-2006, 09:49 PM
KULTULZ's Avatar
aka Duke of URL
 KULTULZ's barnstar
This is a good point in the care of the system. There is a dryer mounted on the compressor that should be changed on a regular basis as it is filled with a moisture dessicant and can/will cause system failure.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "1990 lincoln mark 7 leaky right front air bag suspension"
this is a saver.... GM build codes TooMany2count General Rodding Tech 23 11-21-2008 07:27 PM
front suspension 38 DeSoto 38 special Suspension - Brakes - Steering 3 06-28-2005 10:36 AM
Air bag suspension help. ChrisMiddleron Suspension - Brakes - Steering 12 12-24-2003 05:12 AM
four link air bag suspension on a ranger dmiller Suspension - Brakes - Steering 4 03-29-2003 04:08 PM
air bag suspension bo 1972 Suspension - Brakes - Steering 2 12-27-2002 10:27 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
