Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Electrical
  #1
Old 11-09-2002, 01:39 PM
awbazar awbazar is offline
Post 1990 Olds 98 Keyless Entry Receiver
Where is the programmer plug on a 1990 Olds 98 located? I own a 1996 Ciera and the plug which is shorted to program the receiver is behind a panel on the left side of the trunk. I want to add the 1990 Olds to this same transmitter but I can't find the programmer plug or receiver on the 1990 Olds. I assume it's done the same way...or maybe not!
Old 02-08-2003, 07:48 AM
Jagello Jagello is offline
Post re: 1990 Olds 98 Keyless Entry Receiver
Did you ever find the receiver or the programming plug ?
Old 09-17-2003, 09:37 AM
informan67's Avatar
informan67 informan67 is offline
Just for future posts. There is a black box transmitter behind dash above glove box. You should be able to access the transmitter by dropping the glove box door past the rubber stopper and then reaching up and feeling for a button. It is small but the only one on transmitter. When button is pressed the locks will cycle. Press lock button on each remote you want to program. I believe locks will cycle when you do this to indicate programming was successful.
Old 01-21-2004, 07:06 AM
90 Olds Keyless Entry Receiver Location...
Thank you (informan67) for the advice on the location of the keyless entry receiver. It was exactly where you described it. I have viewed it with inspection mirrors and so far have not found the button. I also felt around the box but could not feel a button anywhere. Is it recessed? Any hint on button location would be useful. My next trick will be to remove the box to find the button when the temperature in my barn gets above freezing unless I can locate it with mirrors or by feel. Thanks for the help so far.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
