1990 s10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2004, 03:28 PM
1990 s10
Have a 1990 s10 4.3 auto. When you shut it off does not start, seems like no spark. Later did start. Now won't start at all. Just replaced plugs and dis. cap and rotor then started right away. Day later it's back to the same. no starting. thanks
Old 07-29-2004, 03:32 PM
suck, squeeze, bang, blow
Last journal entry: finally reeled it in
Without actually testing out the system it sounds like Ignition module and or magnetic pick up coil. Either way, if it's one change the other as well. I had the same problem many times with my GM Vehicles. Usually shortly after they hit about 180,000 Kms.
