-   -   1990 Trans Am hatch adjustment help needed (http://www.hotrodders.com/forum/1990-trans-am-hatch-adjustment-help-needed-231796.html)
cyclopsblown34 04-13-2013 10:05 AM
I'm working on 1990 TA and need to adjust the hatch forward about 1/8". Any tips? I cannot find any more adjustment. Thanks.
tech69 04-13-2013 11:18 AM
look for kinks or a reason why first. I'm assuming the mounting area is pushed back by years of shutting it, but then again without pics I'm guessing here.
cyclopsblown34 04-13-2013 12:59 PM
Good point Henry 500hp at the wheels ,five speed and t-tops are not a good combination either.:thumbup:
deadbodyman 04-15-2013 06:37 AM
Look under the interior panel where the metal deck bolts to the glass there 10mm nuts with big washers,loosen them and you can adjust it.
cyclopsblown34 04-15-2013 08:31 AM
Thanks Michel. I'll check that tonight, I think I've done tried but I've also slept since I last looked at the car. Being old (46) I tend to forget things.
tech69 04-15-2013 08:54 AM
be careful when tightening them for mock up. if the striker is potted metal you don't want to tighten it up too much til it's final.
