1990 Trans Am hatch adjustment help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2013, 09:05 AM
cyclopsblown34's Avatar
Colorsanding painter
I'm working on 1990 TA and need to adjust the hatch forward about 1/8". Any tips? I cannot find any more adjustment. Thanks.
Old 04-13-2013, 10:18 AM
put up or shut up
look for kinks or a reason why first. I'm assuming the mounting area is pushed back by years of shutting it, but then again without pics I'm guessing here.
Old 04-13-2013, 11:59 AM
Good point Henry 500hp at the wheels ,five speed and t-tops are not a good combination either.
Old 04-15-2013, 05:37 AM
deadbodyman's Avatar
Wiki Edits: 11
Look under the interior panel where the metal deck bolts to the glass there 10mm nuts with big washers,loosen them and you can adjust it.
The Following User Says Thank You to deadbodyman For This Useful Post:
cyclopsblown34 (04-15-2013)
Old 04-15-2013, 07:31 AM
Thanks Michel. I'll check that tonight, I think I've done tried but I've also slept since I last looked at the car. Being old (46) I tend to forget things.
Old 04-15-2013, 07:54 AM
put up or shut up
be careful when tightening them for mock up. if the striker is potted metal you don't want to tighten it up too much til it's final.
1990 chevy 350 what's needed for wires to make run? 54chevy3600hotrod55 Engine 1 11-04-2012 12:54 PM
1990 chevy 4x4 wiring diagram needed 1990 chevyguy Electrical 2 01-23-2012 05:31 PM
Vacuum adjustment help needed vbreithaupt Engine 8 04-27-2011 07:13 PM
1990 E-350 w/351W trans problem farna Transmission - Rearend 7 03-09-2007 08:48 AM
Carb adjustment needed? 305Guy84 Engine 5 06-19-2006 11:08 AM
