Trans fluid
First of all, check the fluid while the car is running. You may still be low on fluid. On a more serious note, you should be concerned with where the fluid went to begin with. I suspect a leak somewhere. Once you can remedy the leak I would suggest changeing the trans pan gasket and filter. Dont get me wrong, there could certainly be more serious issues with your trans that may only be addressed by rebuilding. Hope this helps
