-   -   1991 Acura Legend rusty looking trans oil (http://www.hotrodders.com/forum/1991-acura-legend-rusty-looking-trans-oil-229447.html)
apemanbrownhole 02-11-2013 03:02 PM
Ok so i have a 91 acura legend i just bought.
i checked the transmission levels and it wasnt reading so i put a quart of transmission fluid in it. now when i read the levels iits a rust lookin color on the stick. also when i put it in reverse or anything it kinda kicks and when i drive it and it shifts it jumps forward and the engine makes a whining noise like its winding up..is this bad please lend any advice so i can fix it before it gets worse
snakebit68 02-11-2013 03:36 PM
Trans fluid
First of all, check the fluid while the car is running. You may still be low on fluid. On a more serious note, you should be concerned with where the fluid went to begin with. I suspect a leak somewhere. Once you can remedy the leak I would suggest changeing the trans pan gasket and filter. Dont get me wrong, there could certainly be more serious issues with your trans that may only be addressed by rebuilding. Hope this helps
ssimpala 02-11-2013 03:54 PM
Check your radiator. The internal cooler may have gone bad and you're mixing water and trans fluid.
rick 427 02-11-2013 04:35 PM
If that model has a trans pan,you might want to drop it ,and get a better idea of whats going on.
Mad Tiki Customs 02-11-2013 05:02 PM
I hope for your sake you didnt pay much for your Acura. Between the 1/4 and the trans, your looking at a pretty big amount of work there. If your experiencing a banging or jumping when putting it into gear, it could be your engine, and or trans mounts. Honestly, not to burst your bubble, but that car should be just a parts car at most. I would part it and move on to something better of an investment.
apemanbrownhole 02-11-2013 06:48 PM
i didnt pay much 700 bucks...its just a starter car to practice in and get my license but if i can make better for a resale then by all means i want to..all your replys have been helpful except scrapin it. ill deffinatly be making it better for resale though
