1991 bonneville 3.8 coil module
i have a 1991 bonneville 3.8 and the wiring harness sshows resistance in all the wires, but when its plugged up no fire is coming from the coil.What causes this.
HERE ARE SOME POINTERS. HOPE IT HELPS
COIL TEST Remove the ignition coil(s). Using an ohmmeter, check the resistance between the primary terminals on the underside of the coil. The resistance should be 0.50-0.90 ohms. Check the resistance between the secondary terminals. It should be 5,000-8,000 ohms. If the coil failed either test, replace the coil. THIS LINK WILL TEST THE MODULE http://www.autozone.com/autozone/rep...96b43f8038fb5b THIS LINK IS FOR THE CRANK SENSOR TEST http://www.autozone.com/autozone/rep...96b43f8038fb48 THIS LINK IS FOR THE CAM SHAFT SENSOR TEST http://www.autozone.com/autozone/rep...96b43f8038fb56 |
The crank sensor is the heartbeat of the system , without it, nobody goes to work. If your gonna throw a part at it , I would start there. Or if you have a Oscilliscope you can check it all out. This site may give you what you need, and I wont have to type so much http://easyautodiagnostics.com/gm_ig...n_module_1.php Its a little lengthy but it is good info. |
| Testing HEI Coil/Module | Sweet-34 | Electrical | 7 | 04-10-2011 04:21 PM |
| Hypothetical HEI Module/Coil Question | Sweet-34 | Electrical | 2 | 02-11-2008 09:31 PM |
| holley control module no power to coil. | chevelle4542speed | Engine | 0 | 05-09-2006 10:56 AM |
| Coil vs Ignition Module | 1932Fun | Electrical | 8 | 07-23-2004 08:56 AM |
| Electronic Module or Coil. | DTL504 | Engine | 4 | 04-20-2004 09:18 PM |
