1991 Chevrolet K2500 4X4 transmission problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2008, 06:15 PM
Hi!
I have a 1991 Chevrolet K2500 4X4 with a 4L80E transmission and a 454 engine.
The question I have is : I had the transmission rebuilt and had them install a non-lock up torque convertor.The transmission works great but we ran into a problem.When engine is cold transmission shifts 1 to 2- 2 To 3 - 3 to OD. With in 5 mins. you can be going down the road at 65 MPH and transmission shifts back to Drive from Overdrive. You can move the shifter,speedup or slow down and it will not go back in to O/D. Myself and the gentleman that rebuilt the transmission are trying to find out why! Any Ideas! Thanks!
Old 02-23-2008, 07:29 PM
327NUT's Avatar
Just curious....why a non-lockup converter?
Old 02-23-2008, 07:59 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
easiest thing to try is replace the shift solenoids... The solenoid could hold the pressure enough for lower gear , not hold for OD.
Could also be a worn out distributor bushings among other items. Bad speed-O input
A quality scanner with shift control program can up shift the trans into OD.... at a low speed 25-30 mph. Then you mash the loud pedal to the flooor. IF the trans drops back to 3rd gear, the solenoid is not holding pressure.
Hopefully the trans was modified for the non lock up converter
Old 02-23-2008, 08:05 PM
X2 they provide better economy
Shane
Old 02-24-2008, 04:39 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Shane
Uh... say what? Its the other way around. Lockup converters positively lock the engine and tranny together. Non-lockups continually waste energy as heat in a converter that is only connected fluidly.
Old 02-24-2008, 02:34 PM
Seeeking Advice on Torque Convertors!
Can someone explain to me the difference between Lock-Up and Non-Lock-Up Torque Convertors. Also the advantages and disadvantages of both.
I pull a travel trailer in the summer time that weighs 9700 Empty Dry Weight! In the winter time I have a snow plow on the truck. That was one of the reasons I went with a non lock-up convertor.
Old 02-24-2008, 05:47 PM
1991 Chevrolet K2500 4X4 4L80E trans. with 454 CID
Can someone explain the difference to me on a lock-up convertor and a non-lock-up convertor? I had the person that rebuilt my transmission install a non-lock-up convertor because I pull a 31 Foot travel trailer that is 9700Lbs. dry weight,and have a snow plow attached to the truck in the winter. I figured that it would increase the performance of the low end of the truck because when pulling that travel trailer I needed all the help I could get. Did I make a mstake or not! Looking for positive or negtive feedback! Thanks!
Old 02-24-2008, 07:52 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you asked the same question twice.... I merged the threads so members can follow the question on the same vehicle.
lock up & non lock up converters are just that....
a lock up converter has a clutch that is applied inside the converter. This clutch removes all slippage from normal operation of the converter. it is 1-1 with the engine while locked up.
The vehicle computer controls this lock up.
While unlocked ... the lockup converter operates the same as a non lockup converter
IF your trans was not modified for the non lock up converter , damage can result. Over heating is one.
I am surprised you do not get trouble codes if there is a non lock up converter in the truck.
Old 02-24-2008, 07:57 PM
Jmark's Avatar
It appears you have added some extra info to your post since I read it earlier, but i'll add this.
Gleaning from the previous posts, the lockup converter "locks" the engine to the trans, eliminating slippage between the two, resulting in a little better fuel economy.
A non-lockup converter has a certain amount of slippage built in, so it won't stall the engine at idle, but it still slips some at "speed" so there is some waste in economy.
The builder "may" have used a non-lockup converter because they can fail when in the lockup mode AND pulling huge loads, like your trailer. He may have been trying to save you a converter failure down the road but may have missed something or caused another problem since you now have shifting problems.
Mark
Old 02-24-2008, 08:02 PM
327NUT's Avatar
I'm with Curtis.....or he's with me.... and Shane needs to do some homework.
Craig, A lockup converter does exactly that, it locks up in O/D just like you were running a stick shift trans which = no slippage which = no excessive heat which = longer trans life and BETTER fuel economy.
A non lock up slips in O/D which = heat build up.........I think you get the idea. AND if you're pulling that much weight you are really putting a LOT of unnecessary wear and tear on your new trans by not running a lock up conv.
Old 02-24-2008, 08:12 PM
X2 ..was also wondering why they weren running a lock up converter, I was stating that the lockups provide better economy but forgot the comma so it was a little confusing
Sorry about that
Shane
Old 02-24-2008, 09:57 PM
Jmark's Avatar
Really hoping the trans experts will add some tomorrow. I'll toss this in, in the meantime.
Lockup converters are usually not up to the task of maintaining lockup under BIG torque loads. Thanks to a tour of a converter shop I had not long ago, I saw firsthand the one single friction plate that is inside most LU converters. That is why almost every vehicle manufacturer says to NOT tow in OD or in LU. There are finally some HD multi disk converters coming on the market for the towing crowd.
Mark
Old 02-25-2008, 12:06 AM
327NUT's Avatar
To Shane.........sorry, didn't get the "X2"....my apologies, Dave
Old 02-25-2008, 03:14 AM
In your honest opinion: Do you think I made the right move! Be Honest! I don't want to ruin this transmission!
Old 02-25-2008, 07:04 AM
Jmark's Avatar
We will need to wait out some more answers from the experts. As Crosley has stated, to run with LU disabled, the trans needs to be set up accordingly. Hopefully he or the other trans builders will join in with some good replies.
Mark
3 Speed Automatic Transmission Problems - 93 Pontiac Sunbird JOEMAMA Transmission - Rearend 4 04-17-2003 06:35 AM
700R4 Transmission shifting problems Judd Wymer- VA Transmission - Rearend 1 01-10-2003 03:17 AM
Transmission problems kemo Transmission - Rearend 2 11-21-2002 01:48 PM
move over motor now I got transmission problems cuda66 Transmission - Rearend 3 11-11-2002 04:19 PM
Transmission swap.....now experiencing problems Oldsdiesel Transmission - Rearend 2 10-10-2001 06:31 PM
