1991 chevy 4x4, 350 engine, transmission swap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2010, 04:01 AM
I have a 91 chevy 4x4 350 engine with a 700r4 originally is it possible to swap to a 350 or a 400 transmission and keep four wheel drive.
My brother has both of these transmissions freshly rebuilt and he seems to think that either of the two could bolt right up.
Old 01-11-2010, 06:52 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the t-350 or t-400 will bolt to the engine with the correct converter for the trans.
the 3 speed automatic trans will NOT bolt to the transfer case in your truck without changes.
t-350 trans is shorter and shorter output shaft than the 4l60 trans.
t-400 has a 32 spline output shaft , the 4l60 trans has a 27 spline shaft
51 chevy engine swap poorman51 Engine 4 06-13-2005 01:48 PM
8.1 marine spec engine swap into a 57 chevy pickup customike Engine 2 12-04-2004 12:19 AM
1978 grand prix chevy 350 swap threesand9s Engine 5 06-28-2004 03:31 PM
55 chevy engine swap timrocket72 Engine 0 11-04-2003 10:33 PM
Stude to Chevy engine swap Dawger General Rodding Tech 3 07-11-2003 08:15 PM
