1991 Chevy truck AC/vent type popping noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2007, 08:41 PM
THis is wierd..............If everything on AC control is off and I hit the REC button, this popping noise goes away. It does at all other times, regardless of heat, def, AC, top vents, center or floor. THe sound is down low, towards heater core, but again, the only thing that makes the popping noise quit is hitting the REC button.............any ideas on what this is? THanks
Old 07-12-2007, 08:48 PM
302 Z28's Avatar
Other than the noise do the controls seem to function properly? If not, there is an electronic actuator that operates an air door that switches between heat and AC. The actuator is a small motor that drive a gear set and a rheostat. I have seen the gears strip out and make the noise you are describing. The actuator is about $60 and is in the center behind the dash. You must remove the glove box to get to it.
Vince
Old 07-12-2007, 09:13 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Check the heater motor for junk that has fallen inside it from the defrost vents..this usually is the first culprit of "weird noises"..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 07-13-2007, 09:17 PM
Thanks !!!
Old 07-13-2007, 09:22 PM
T-bucket23's Avatar
Wiki Edits: 26
Broken air diverter doors are common on those and will make strange noises. May be when you hit the recirculate button it is redirecting air flow away from the broken door so the noise stops
Old 07-13-2007, 09:31 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Pull the Heater motor FUSE, and run the controls through their paces..
If the noise goes away, it's probably junk..If it stays it may be doors or vents..
Doc
Innovations
Old 07-19-2007, 07:39 PM
sounds exactly like the mode door motor, my 91 did the same thing and thats what we replaced to fix it. hope it helps, Bob
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
More Chevy Truck Operator's Manuals ONLINE! khardy General Rodding Tech 4 02-01-2007 11:27 PM
Car 235ci into '53 Chevy Truck New2theart Engine 8 10-17-2006 01:37 AM
53 chevy panel truck huligar General Rodding Tech 12 04-27-2006 04:53 AM
94 chevy truck maybe dist./ignition problem,please help! bluesmanjesse Engine 14 11-19-2004 04:31 PM
