-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   1991 Escort 1.9 will not start (http://www.hotrodders.com/forum/1991-escort-1-9-will-not-start-75353.html)
Mr.NutCase 12-04-2005 01:59 PM
My brother's 1991 Escort 1.9 will would not start yestarday. It would almost start but it shut down a few seconds later,so we called a tow truck to bring the car to our house.
At home I sprayed carb cleaner in the throttle body, would not start, so is not a fuel problem and I pulled all spark plugs and they smell like gas. The starter and battery is good they were checked at an Murrays Auto store. The Alternator was installed last year( same alternator was fix). My dad and I think the problem is around the ignition system. I looked at the Crankshaft pulley and it moves along with the s. belt.
Another question is there a way to test a Alternator?
randywrench 12-04-2005 02:51 PM
The 2 most common no start problems on Escorts are timing belts
and ignition control modules!
oldred 12-04-2005 02:54 PM
Nut, you really should try this in the engine forum as I think you would get a better response. Did you check for spark? You are aware that these engines are notorious for slipped/broken timing belts? Check one of the plug wires for spark and let us know.
Mr.NutCase 12-04-2005 03:39 PM
ok! thanks for info
Mr.NutCase 12-06-2005 12:11 PM
I posted in the engine forum, got a fast respond from other members, the timing belt is broken, thanks for info!!
