1991 GMC 1500 gear ratio change? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2010, 07:50 PM
okay guys, been thinking of changing my rearend ratio for a while, pretty sure i have a 3.42 in 91 gmc 1500. want to set this truck up specifically for cruisin. dont need good take off or nuthin. it has 5.7 v-8 with 700r4. was wonderin if it was worth my time to drop to 3.08 or possibly 2.73 in this truck. just lookin for mileage and dont want a 4 cyl. i like my truck. thanks
Old 06-28-2010, 09:26 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I take it this is a 2-wheel drive, What size rear tire are you runing? The 3.42 is a pretty good all around gear IMHO.
Cole
Old 06-29-2010, 09:01 AM
yea, 2wd. i'm runnin 235/15's on stock SS truck wheels
Old 06-29-2010, 09:25 AM
big gear head's Avatar
High Performance Rear Ends
Don't go too far or you won't be able to use overdrive any more. If you lug the engine too much your mileage might get worse. The 3.42 is a good ratio with overdrive. You might try a taller tire first.
Old 06-29-2010, 11:15 AM
mine has got noise in it, and i've found one local salvage with 3.08 GU4 code. as this seems to be the same set up, 350 with 700r4 and $250 bucks with 78k miles. thanks fellas
Old 06-29-2010, 12:00 PM
The 3.08 would probably work fine. I wouldn't go to the 2.73.
Old 06-29-2010, 04:35 PM
Thanks Again
Need some help sorting out tranny ratios and rear end ratios firstgear Transmission - Rearend 3 11-06-2008 08:39 AM
97 gmc 1500 97 GMC 1500 Internal transmission squeak Longbox262 Transmission - Rearend 5 06-25-2008 06:41 PM
3.70 rear end gear change lori-due Transmission - Rearend 3 12-28-2002 09:25 PM
chnging gear ratio RAYRAY Engine 5 10-21-2002 03:22 PM
Speedometer Gear Change ? bigjoedo Transmission - Rearend 3 07-04-2002 07:52 PM
